Activity Forums Adobe After Effects fx, hanging by a thread
  • fx, hanging by a thread
    Posted by Josué Ruiz on June 23, 2008 at 9:30 pm
    hello friends that I would like to help …. I would like to see how I can make a fx, I have a imgan sets a framework, we say this with a nail hanging on a thread and I want to be balance from one side to another, and tried to f9 in the key frames but not in a movement Naturally, there is some expression for this, or as I do. thanks.
    Josué Ruiz replied 18 years, 2 months ago 2 Members · 4 Replies
  • Mike Clasby
    June 24, 2008 at 6:00 am
  • Josué Ruiz
    June 24, 2008 at 2:10 pm
    if it is correct, but you can help me now so that the movimito is constant and do not subside, namely that the pendulum is constant, as I do?
  • Mike Clasby
    June 24, 2008 at 5:17 pm
    You could use the same expression and set the decay to 0 (zero) and it will swing constantly at the same rate. Then set the velocity and amplitude in the expression to get the swing you want.
  • Josué Ruiz
    June 24, 2008 at 7:05 pm
    ok, thank you very much, was a great help your explanation, thanks.
