Activity Forums Adobe After Effects Expressions FX Expression for Days Hours Min Sec Countdown?
  • Dan Ebberts
    November 13, 2016 at 5:48 am
    This should be close:
    function padZero(n){
    s = "" + n;
    if (s.length < 2) return ("0"+s);
    return s;
    dayStart = 5;
    hrStart = 0;
    minStart = 0;
    secStart = 0;
    clockRate = 10;
    totalStartSec = ((dayStart*24 + hrStart)*60 + minStart)*60 + secStart;
    curTotalSec = totalStartSec - Math.round((time - inPoint)*clockRate);
    curDay = Math.floor(curTotalSec/(24*3600));
    curHr = Math.floor((curTotalSec%(24*3600))/3600);
    curMin = Math.floor((curTotalSec%3600)/60);
    curSec = curTotalSec%60;
    padZero(curDay) + " " + padZero(curHr) + " " + padZero(curMin) + " " + padZero(curSec)
    Dan
  • Sara Martinez
    November 15, 2016 at 2:39 am
    Thank you so much Dan!! You’re incredibly kind. This worked wonderfully. My only set back now is the rendering, but the script is exactly what I needed and it works great.
  • Elvis Muchara
    July 27, 2018 at 4:17 pm
    Hi, how can I change the time in this expression, say I want it to start at 05:10:15 and continue?
  • Dan Ebberts
    July 27, 2018 at 4:35 pm
    I’m not sure what you mean exactly, but maybe like this:
    s = "" + n;
    return s;
    hrStart = 5;
    minStart = 10;
    secStart = 15;
    clockRate = 1;
    totalStartSec = ((hrStart)*60 + minStart)*60 + secStart;
    curTotalSec = totalStartSec - Math.floor((time - inPoint)*clockRate);
    padZero(curHr) + ":" + padZero(curMin) + ":" + padZero(curSec)
    Dan
  • Salim Maurice
    July 3, 2020 at 6:12 pm
    Hi Dan,
    Thanks so much for this expression, I am trying to use it but I’d like to connect the trim path to your expression do you think this is possible?
    See screenshot
    Thanks very much in advance!!
  • Dan Ebberts
    July 3, 2020 at 11:54 pm
    I’m not sure what you’re after exactly, but this example would drive the Trim Paths End value from 100 to 0 as the seconds count down. Probably some form of this would do what you want:
    t = thisComp.layer(“time”).text.sourceText.value;
    sec = parseInt(t.split(” “)[3],10);
    linear(sec,0,60,0,100)
    Dan
  • Salim Maurice
    July 4, 2020 at 5:50 am
    Thanks for your fast feedback Dan! I dropped the expression but I am getting this error
    any idea why ?
    Thanks again for your time.
    Salim
  • Dan Ebberts
    July 4, 2020 at 6:27 am
    It might have to do with how you have the time formatted, but I can’t tell from your screenshot.
    Dan
