Activity Forums VEGAS Pro FX Copy/Paste
  • FX Copy/Paste
    Posted by David Katauskas on May 2, 2010 at 4:09 am
    Is there a way to copy the effects from one video clip to another?
    Also, one the same line of thinking, can I save an effects group for application later?
    David Katauskas replied 16 years, 4 months ago 2 Members · 2 Replies
  • Graham Bernard
    May 2, 2010 at 6:47 am
    Copy and then “Paste Attributes”. This will get your FXs and ALL your attribs from EventA to EventB. Be warned, this will also take any Pan/Crop adjustments you have made.
    You can save your “Chain” of FXs as a Plugin Chain. This will then reside in your Plug-in Manager under Video FXs. I always start my saving with my Initials to determine which are what! The folder tree in Plug-in Manager suffers from senior moments – on a permanent basis. Meaning if you make Folders and are organised as you are offered to be, then don;t be surprised if the Folder is then collapsed – again.
    HTH
    Grazie
  • David Katauskas
    May 3, 2010 at 8:18 pm
    Thanks Graham, that worked.
