Activity Forums Apple Final Cut Pro Legacy FW800 fast enough for ProRes 422(HQ)?
  • FW800 fast enough for ProRes 422(HQ)?
    Posted by Alfred Guzzetti on June 22, 2007 at 5:08 pm
    I did a short test capturing and playing back a HDV clip to a FW800 hard drive using ProRes 422 (HQ) at 1080i and saw no problems. Has anyone found problems using FW800 with this codec?
    Alfred Guzzetti
    Mac Pro Quad 2.66GHz 4GB RAM
    Intensity Pro card
    OS 10.4.9
    FCP 6.0
    Alfred Guzzetti replied 19 years, 2 months ago 3 Members · 3 Replies
  • Chris Borjis
    June 22, 2007 at 5:10 pm
    Since uncompressed capture is possible over fw800 ProRes should be fine.
  • Sean Oneil
    June 22, 2007 at 5:47 pm
    This is a confusing discussion. Capturing from a hard drive? It’s HDV, and it’s ProRes?
    FW800 is 800mbps theoretical max bandwidth. ProRes is 200mbps, so it will fit. Uncompressed 1080i HD 8-bit is about 1000mbps, so it will not.
    No tape decks use FW800. So you can’t capture from it. The AJA IO/HD interfaces with the computer using FW800. It does the encoding to ProRes itself, thus allowing video to fit over FW800. It can’t do uncompressed HD nor can any device because, as I just said, that is impossible over FW800.
    Sean
  • Alfred Guzzetti
    June 22, 2007 at 7:10 pm
    I meant capturing to a FW800 drive and playing back from it. Sorry for the confusing wording.
    Alfred Guzzetti
    Intensity Pro card
    OS 10.4.9
    FCP 6.0
