Activity › Forums › Apple Final Cut Pro Legacy › FW800 7200RPM or Internal Hard Disk 7200RPM?
  • FW800 7200RPM or Internal Hard Disk 7200RPM?
    Posted by Romy Marx on August 9, 2010 at 3:03 pm
    I’m about purchasing new MacBook Pro.
    and I’d like to know is it reliable to capture and edit using the internal Hard Disk I’ll customize to 7200 rpm.
    Or i Must use external Hard Disk 7200rpm connected using FW800?
    Mark Laslo replied 16 years, 1 month ago 8 Members · 14 Replies
  • 14 Replies
  • Rafael Amador
    August 9, 2010 at 3:26 pm
    External.
    Let the internal HD for the System and Applications and put the media in another HD.
    rafael
    http://www.nagavideo.com
  • Loic De lame
    August 9, 2010 at 3:34 pm
    Definitely second that. Best to keep the media separate from the system drive if possible for performance.
    ~ Loïc
  • Romy Marx
    August 9, 2010 at 3:37 pm
    I know the external is safer.
    But i ask regarding the performance..
    is both same speed?
    ROMY
  • Nace Zavrl
    August 9, 2010 at 3:44 pm
    Definitely use the external for editing, as using the same drive for editing and running applications, slows you down quite a bit. You will get much better performance editing on the external drive.
    Nace,
  • Loic De lame
    August 9, 2010 at 3:58 pm
    Technically, no, FW 800 and an internal drive aren’t the same speed. FW800 is 800Mb/s (megabits, not bytes) and internal drives in computers these days use eSATA, rated at 3Gb/s (gigabits).
    So in MB (megabytes), that would put FW800 at 100MB and eSATA at 375MB. This is of course all theoretical. Hard drives though can only do 90MB/s. So these interfaces won’t be your bottleneck.
    This is all the theory and numbers that I know. Correct me if I’m wrong.
    But in either case, it depends on what format you’re going to be editing. Considering that you’re using a MacBookPro, you’re not going to be doing uncompressed footage with it. So you should be fine.
    Again, as everyone is saying, external is better. Yes, you can edit on your system drive, but it isn’t going to help you that much.
    ~ Loïc
  • Mark Laslo
    August 9, 2010 at 4:32 pm
    I have a quick question along these lines.
    Does it matter which drive I store my project files on. Right now I have them on the same drive as the media. My system files and program files are on a separate drive.
    Mark
  • Shane Ross
    August 9, 2010 at 4:45 pm
    Project files should be on the system drive. Media on external. If your media drive died, then you’d lose everything. Not good. Back up the project file to the external, just in case the system drive dies. Have a backup.
    As for where to store media. Internal system drive will work for DV, but beyond that, gotta have an external. Pretty much an editing “must have.”
    Shane
  • Rafael Amador
    August 9, 2010 at 4:51 pm
    Hi Loic,
    Is not just about speed, but about sharing tasks.
    With 2 HDs you have 2 “heads” instead of one reading and writing.
    Make things easier for your system.
    Cheers,
    rafael
  • Mark Laslo
    August 9, 2010 at 7:31 pm
    I just want to double check – could the “external” drive be a separate internal SATA drive if using a Mac Pro?
  • Nace Zavrl
    August 9, 2010 at 8:01 pm
    Yes, that would actually be even better, but you have to make sure that you keep your applications and system files separate from that drive.
    Nace,
