Activity › Forums › Apple Final Cut Pro Legacy › FW400 vs FW800 Daisy Chain
  • FW400 vs FW800 Daisy Chain
    Posted by Christopher Targia on July 16, 2010 at 4:27 pm
    My co-worker has an older model macpro and only one FW800 port and two external HDDs. Would it be faster to connect a second External HDD through daisy chaining FW800 or to connect the second drive into the FW400 port?
    MacPro Octo Core Intel Xenon 2.8Ghz 6GB DDR2 Ram
    FCP 7.0.2
    -I highly recomend el Gato Turbo264HD-
    Jeremy Garchow replied 16 years, 2 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    July 16, 2010 at 5:05 pm
    [Christopher Targia] “Would it be faster to connect a second External HDD through daisy chaining FW800 or to connect the second drive into the FW400 port? “
    Both fw400 and 800 share the same bus. I’d stick with the fw800 daisy chain as the fw400 port is half the speed.
  • Christopher Targia
    July 16, 2010 at 5:23 pm
    Great thanks, does anyone know the speed of FW800 daisy chain? compared to direct FW800?
    FCP 7.0.2
  • Jeremy Garchow
    July 16, 2010 at 5:24 pm
    [Christopher Targia] “Great thanks, does anyone know the speed of FW800 daisy chain? compared to direct FW800? “
    What do you mean? It runs at fw800 speed (potentially 800mb/sec).
    July 16, 2010 at 5:55 pm
    even through daisy chaining? wouldn’t running two drives through the same port slow them both down?
    FCP 7.0.2
  • Jeremy Garchow
    July 16, 2010 at 5:57 pm
    [Christopher Targia] “wouldn’t running two drives through the same port slow them both down? “
    A little, but not more than using a fw400 connection.
    You can easily test this by running the AJA System Test which is downloadable for free from AJA.com
    Jeremy
