Activity Forums Apple Final Cut Pro Legacy FW Output Workaround
  • FW Output Workaround
    Posted by Paul Turlick on August 10, 2007 at 5:33 pm
    Hey-
    I’ve posted this before with regards to outputting via FW to a Panasonic 1400. I was told there is an audio crackle and sure enough…there is. Some said it may have been fixed in 10.4.10 but seemingly not. I’m thinking the only way to get it out clean is to move it to another machine for output. Any other thoughts would be appreciated…
    Thanks –
    Paul
    Jeremy Garchow replied 19 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 10, 2007 at 5:48 pm
    It’s still there? I haven’t had time to check and many thanks for this update. Outputting via HDSDI is the only way then. You cannot do an audio only insert on that deck (at least I did not find a way and I tried a bunch).
    Jeremy
