Activity Forums Apple Final Cut Pro Legacy FW Hard Drive Crashed
  • FW Hard Drive Crashed
    Posted by Tony on September 19, 2005 at 9:23 pm
    Hello all,
    I’m having a little issue with one of my firewire hard drives. I’ve been using this hard drive for a number of years and it’s been working fine. I tried booting it this morning, and the drive would not appear on the desktop.
    I tried searching for it in Disk Utility and System Profiler, and it does not appear. I tried using Disk Warrior, and again it would not appear.
    Tried on a number of different computers, and still nothing.
    Does anyone have any suggestions?
    Usually when something like this happens I get a warning that says “You’ve inserted a disk Mac OS can not read, would you like to format it?” that warning never came up.
    Any help would be appreciate, since I do have important projects on the drive.
    Thanks.
    –T
    Steve Eisen replied 21 years ago 3 Members · 2 Replies
  • Kevin Monahan
    September 19, 2005 at 9:33 pm
    If Disk Warrior can’t bring your directory back to life, IMHO, you’re pretty much hosed. It’s possible that a component of the FireWire case wore out, then the contents of the drive still might be there. Pull the drive, pop it into the tower, set the pins correctly, reboot and see if it mounts.
    From now on, always unmount external drives before shutting down. It’s something not many people do, but should do. I’ve never seen a FireWire drive go bad on me. Well, there was that one that I dropped–yeesh…..
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Steve Eisen
    September 20, 2005 at 2:49 am
    Data Rescue X saved me once. prosofteng.com Good luck.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 2.45 TB External Stor
