Activity › Forums › Apple Final Cut Pro Legacy › FW 800 and Uncompressed 8-Bit
Posted by Conor Flynn on August 30, 2006 at 3:23 amIf I have Uncompressed 8-Bit media on an external hard drive, is a FireWire 800 cable fast enough to play it in real time on FCP?
Tom Meegan replied 20 years, 1 month ago 4 Members · 3 Replies -
Richard Harrington
August 30, 2006 at 5:08 pmSeveral issues at play
1. Dedicated FW 800 card.. not system Bus
2. Striped Drive Array liek G-Raid or Big Disk Extreme
3. How Full Drive isBut yes. I have done it… not a recommended configuration though
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
Shane Ross
August 30, 2006 at 11:25 pmI too have done it, with a couple G-Raids. But they differ from other FW800 drives in that they are 2 hardware raided drives in one enclosure, so they get 85MB/s…great for uncompressed 8-bit. One drive FW800 drives might not cut it.
Shane
Littlefrog Post
http://www.lfhd.net -
Tom Meegan
August 31, 2006 at 2:58 amI used two G-RAID 500s striped together for an 8-bit project. The programs aired on SPEED Channel. Worked well, both for capturing and editing.
If you go with this configuration, and you have real deadlines, I highly recommend a back-up of your captured media to another FW800 disk or disks at the end of each edit session. Although G-Raids are very reliable, you only have to lose one of the enclosed drives to lose everything – that is the nature of RAID 0.
Sure, you could go back and re-capture, but many projects can’t afford that loss of time.
The peace of mind was worth the time and expense.
Another option would be the RAID 3 solution from G-Tech or the RAID 5 solution from LaCie.
It depends on your and/or the project’s budget and risk tolerance.
Tom
