Activity › Forums › Apple Motion › Fuzzy shapes
  • Andreas Zeitler
    September 1, 2012 at 6:40 pm
    I’ve been asking this question recently as well. It’s driving me nuts. As far as I’m concerned there are no half-pixels.
    Long story short: No answer yet. So not possible.
  • Ben Dansby
    September 1, 2012 at 7:18 pm
    Very frustrating indeed.
  • Simon Ubsdell
    September 2, 2012 at 4:36 pm
    As a workaround, try setting the Falloff of your Shape Fill to 1000.
    This will crop off the semi-transparent antialiasing pixels.
    You will however need to increase the dimensions of your shape slightly to compensate.
    Also make sure that the shape position Transform isn’t using fractions of a pixel.
    Not a perfect solution but it might be of use to you.
    Note that if you are using anything other than perfect squares or rectangles you will get stepping on any non-straight edges because you will have effectively turned off the anti-aliasing.
    Simon Ubsdell
    http://www.tokyo-uk.com
