Activity › Forums › Adobe After Effects › Fuzzy edges to drawn images
  • Fuzzy edges to drawn images
    Posted by Loz_brghton on February 13, 2006 at 5:52 pm
    Hi there
    Can anyone tell me how to make sure I can start a drawn project from Flash>AE> Premiere without having fuzzy/jagged edges to my work in Premiere?
    I want to draw in Flash (weight of 8 line drawing) and import direct into AE. I have done this but when it goes to Premiere it all looks jagged. Do I need to import into Photoshop first and make a change to the drawing in order to ensure field order? Skye Sweeney (C Cow) has advised me to check my field order to make sure if is upper or lower. I have done this in AE, but am still having a jagged edge to my drawings in Premiere. All is fine in AE. Do I need to check filed orders in Flash, Photoshop, Premiere and AE? And do I need to check my DV cam that I am outputting to to make sure if its field order?
    If anyone knows the full process for this or knows of a website that can take me through the process I would be eternally grateful. Its driving me mad.
    Loz
    Loz_brghton replied 20 years, 7 months ago 2 Members · 2 Replies
  • Aanarav Sareen
    February 13, 2006 at 7:53 pm
    What are your export settings in Flash? and After Effects?
  • Loz_brghton
    February 14, 2006 at 7:08 pm
    Hi there
    I am eporting a Flah image as an Illustrator file. I have tried continous rasterization and still no joy. When I exprot into AE its PAL widescreen and when I export its all on best with no compression.
    loz
