Activity Forums Blackmagic Design Fusion Fusion Proxy?
  • Fusion Proxy?
    Posted by Murat Egretli on April 29, 2018 at 8:00 am
    Hi there,
    If you use DaVinci Resolve, you’ll probably know “Generate Optimized Media” option. To edit Ultra HD videos fluently, it resizes the video and creates a cache for it. I don’t know if fusion has a similar feature or not. I need some info. Thanks.
    Murat Egretli replied 8 years, 4 months ago 2 Members · 2 Replies
  • Marco Feil
    April 30, 2018 at 8:39 am
    Theres a PRX button on the lower right under the timeline. Right click it to choose which proxy level you want – it then only calculates one out of every x pixels.
    You can also specify a proxy file in each loader node which will be used when you press the PRX button.
  • Murat Egretli
    April 30, 2018 at 7:47 pm
    Thank you 🙂
