Activity Forums Blackmagic Design Fusion Fusion Expression
  • Fusion Expression
    Posted by duccio lucchesi on September 29, 2022 at 8:48 pm
    hello!
    i come from nuke and i use a lot the TCL expression “frame%1*X”, the operation basically create a ramp every frame from 0 to 1 multiplied by X value.
    i use it to create motion blur effect without move my subject, more or less like directional blur.
    there is a way to do the same in Fusion?
    i try with “frac(time)” expression, it does allmost the same result, but only in frame 0.
    thanks!
    Duccio
    jackky joy replied 1 year, 9 months ago 2 Members · 1 Reply
  • jackky joy
    October 31, 2024 at 5:10 pm
    I’ve been playing around with similar effects in Fusion, and I found that using a combination of the Time node and a Ramp node works pretty well. What I do is create a ramp from 0 to 1 and then multiply it by whatever value you want for the effect. You can use an expression like time * X in a Merge or Transform node to get that motion blur going without being stuck at frame 0.
