Activity Forums Blackmagic Design Fusion Fusion 8 Mac not loading QuickTime RGB Alpha, PNG codec
  • Fusion 8 Mac not loading QuickTime RGB Alpha, PNG codec
    Posted by Fabio Cormack on April 13, 2016 at 10:57 am
    Hi There
    a quick help would be much appreciate please:
    Fusion 8, Mac, El capitan, not loading files on this format: QuickTime RGB + Alpha, Video Codec: PNG
    Do I need to convert these files? If yes for what format in order to preserve alpha? Compressor would work for conversion?
    Thank you so much!!!
    Fabio Cormack
    Davinci 8 – Tangent Wave – Decklink HD Extreme 3D+
    Final Cut Suite
    Adobe CS5.5 Suite
    Rio de Janeiro – Brazil
    Fabio Cormack replied 10 years, 5 months ago 2 Members · 4 Replies
  • Simon Ubsdell
    April 13, 2016 at 11:24 am
    PNG compression is not supported to QT movies. Here’s the list of compression types that are supported:
    Simon Ubsdell
    tokyo-uk.com
  • Fabio Cormack
    April 13, 2016 at 11:28 am
    Thank you so much Simon!
    Converting the files to QT ProRes + Alpha is working – I’m using Apple Compressor – is there any other way to go to not loose quality?
    Fabio Cormack
    Final Cut Suite
    Adobe CS5.5 Suite
  • Simon Ubsdell
    April 13, 2016 at 11:35 am
    Go for one of the Uncompressed options if quality is very, very important – otherwise, I would opt for ProRes 4444 which should be plenty good enough for most purposes and will be easier to work with. Conversion through Compressor should be fine.
    Simon Ubsdell
    tokyo-uk.com
  • Fabio Cormack
    April 13, 2016 at 11:38 am
    Once again, thank you so much
    I think ProRes 444will work fine 🙂
    Have a great day!
    Fabio Cormack
    Final Cut Pro X
    Fusion 8 – Adobe CC Suite
