Activity Forums Apple Final Cut Pro Legacy FUSION 500p HD suggestions
  • FUSION 500p HD suggestions
    Posted by Stephen Vilas on December 27, 2010 at 2:35 pm
    I have 2 x Fusion 500P, each one containing 5 x 1TB Samsung F1 discs.
    they are set up in Raid 0. I use one as an active RAID tower from which I edit current film projects. the second one is the backup device. I use an app called Tri-Backup to sync these two after each editing day.
    I want to replace the 1TB discs with 2TB discs. 10 new discs in total.
    is this a good idea and which ones should I go for? i have been advised not to go for WD or Seagate, but opt for Samsung or Hitachi. just not sure which are reliable 2TB models.
    David Roth weiss replied 15 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    December 27, 2010 at 2:49 pm
    Check their website for qualified drives:
    https://sonnettech.com/product/fusiond500p.html
    Then click “techinical specifications”.
  • David Roth weiss
    December 27, 2010 at 3:54 pm
    Yep, it’s always a good idea to check with the manufacturer. They usually build, test, and tweak their drivers with only one brand of drives, and if you use that brand you’re typically golden.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
