Activity Forums Adobe After Effects Furnace_Steadness 1.0: how to use?
  • Furnace_Steadness 1.0: how to use?
    Posted by Walkingduck on April 6, 2006 at 11:11 pm
    Currently, I’m using this plugin to stablize shaky footages, but I haven’t gotton any luck, so I was wondering if anyone has any tips for it.
    I hope I can get some help from you folks on how I should set the parameters and all.
    The user ref doesn’t really tell me anything other than just applying it.
    Anyone has any experience using this “Furnace_Steadness”?
    thanks a lot.
    Andrew Yoole replied 20 years, 4 months ago 4 Members · 3 Replies
  • Andrew Kramer
    April 7, 2006 at 4:23 am
    Set the plugin to look accross frames instead of current frame which is the default. set the frames to look accross to about 5-10 and that should do it. don’t use the current frame stabilize part it sucks.
    Andrew
  • Jack Binks
    April 7, 2006 at 10:40 am
    Hi Walkingduck
    If you want we’ll set you up an ftp account on our server where you can upload the footage in question. We’ll have a look at the problem and see if we can come up with some good settings for you? If this suits you, pop an email over to support at the foundry.co.uk and we’ll get the account set up.
    Cheers
    Jack
    The Foundry, UK
  • Andrew Yoole
    April 8, 2006 at 2:28 pm
    Now THAT’S service!! 🙂
