Activity Forums Adobe After Effects funny layer behavior.
  • funny layer behavior.
    Posted by Malcolm Desoto on August 10, 2007 at 8:19 pm
    I went back to my “walls” precomp (which is obviously all my wall layers that make up the room) to adjust a few layers.
    When I came back, all the layers were acting wonky.
    wonky layers
    That door and all those pictures you see in the left corner are supposed to be on the other side of the wall.
    The 3D layer switch is still on. I don’t know what the deal is.
    Any ideas what happened?
    Malcolm Desoto replied 19 years, 1 month ago 2 Members · 2 Replies
  • Darby Edelen
    August 11, 2007 at 5:17 am
    I assume your pre-comp is a 3D layer with collapse transformations enabled, if so did you insert any 2D layers into the pre-comp? This would break the 3D-ness of the pre-comp in the main composition, you basically have to imagine (when using collapse transformations) that every layer is being imported into the main comp exactly as it exists in the pre-comp, all blending modes and layer swatches will behave accordingly.
    If you added any 2D adjustment layers or 2D Null objects, these could break the 3D effect.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Malcolm Desoto
    August 13, 2007 at 1:41 am
    Yeah, I have no idea what I did. I just deleted the pre-comp from the timeline and then dropped it in again from the project window. Everything’s cool now.
