Activity Forums Adobe After Effects funky Foam FX in After Effects
  • funky Foam FX in After Effects
    Posted by Bucktooth on March 17, 2006 at 9:15 pm
    Hello,
    I am working with the Foam effects in AE 6.5 and I was wondering if anyone knows how to remove the “particle emitter points” from the foam simulation. When I render out the foam as a movie file (with alphas) I keep seeing the the teeny-weeny particle-points before they become full bubbles, …and this is not what I want, I just want the bubbles – not the points.
    Hmmm…. seems that as I’m writing this I’m realizing something I could do… I have an idea! Unless I’m mistaken, I could just increase the “Particle Growth” slider so that the bubbles are “instantly formed”, right?, that way the emitter points might not show up anymore…. I will try this, see if it works….
    ciao!
    Franco Strobbia replied 15 years, 8 months ago 2 Members · 2 Replies
  • Bucktooth
    March 17, 2006 at 9:29 pm
    Yes indeed….
    So, to remove the funky particle-points all I did was crank the “Bubble Growth Speed” variable to “1” so that the bubbles are “instantly” formed instead of starting out at a 0.0 size … seems like they missed this helpful detail in the Total Training tutorial on Foam Effects.
  • Franco Strobbia
    December 31, 2010 at 8:36 am
    No, they don’t missed anything.
    Think it again.
    What’s that? emmiter points? NO. There are bubbles growing!
    So, YOU missed what you’re dealing, or simply can´t undestand how it works.
