Activity Forums Compression Techniques funky compression request
  • funky compression request
    Posted by Michael Black fcp on September 2, 2006 at 7:15 pm
    Got these specs from a client. My first thought was, “We can do that.” but then I sort of remembered MPEG-2 maxing out at 9 Mbps. Is this compression even possible?
    Video files must be encoded to the following specification:
    MPEG-2
    GOP Pattern: I Frames only
    Image Size: 720×480 NTSC
    Pixel Aspect Ratio: Square pixels (VGA)
    Frame Rate: 29.97fps
    Bit Rate: 20 mbps (20000 kbps)
    Bit Rate Control: Constant bit rate
    Quality/speed: Highest Quality
    Deinterlace
    Charles Simonson replied 20 years ago 2 Members · 1 Reply
  • Charles Simonson
    September 3, 2006 at 3:58 am
    Yes. This can be done if your encoding app supports it. MainConcept, ProCoder, and Compression Master support this. Cleaner, Compressor, BitVice, and Squeeze do not.
