Activity Forums Adobe After Effects Expressions Function works on dialog but not on a palette
  • Function works on dialog but not on a palette
    Posted by Rodrigo Aben on May 17, 2020 at 9:40 pm
    With the help of Andrei I’ve arrived at the code below that works great, but stops working when assigned to a button on a ScriptUi palette. It simply bypasses the ifs in the while loop. I have to change from new Window(“palette”) to new Window(“dialog”) for the function to work.
    Since I’m trying to create a dockable script it would be great to have it working on a palette.
    Am I missing something?
    function Detect(){
    var comp = app.project.activeItem;
    var videoLayer = comp.selectedLayers[0];
    var time = comp.time;
    var frame = Math.round(time / comp.frameDuration);
    var opacityLevel = videoLayer.property("Transform").property("Opacity");
    var threshold = 48.0;
    above = false;
    while (frame <= 100) {
    t = frame * comp.frameDuration;
    if (above) {
    if (opacityLevel.valueAtTime(t, true) != threshold) {
    frame++;
    above = false;
    } else if (opacityLevel.valueAtTime(t, true) == threshold) {
    above = true;
    var myMarker = new MarkerValue("Mark");
    videoLayer.property("Marker").setValueAtTime(t, myMarker);
    frame++;
    Rodrigo Aben replied 6 years, 1 month ago 3 Members · 3 Replies
  • Tomas Bumbulevičius
    May 18, 2020 at 7:47 am
    Since you hit the button in a script panel, does this still remain true?
    Overall, a layer must always be selected in the comp, thus you surely need to define try/catch in case selection is not made.
    Find out more:
    Motion Graphics Design & After Effects Tutorials
    On YT
    On VH
  • Andrei Popa
    May 18, 2020 at 8:16 am
    Off topic: Please don’t start your function name with capital letters.
    On topic:
    Idk if the problem is the one specified by Thomas. But if so, why don’t pass the composition as a parameter in your function?
    Something like
    function detect(comp) {
    above = false;
    if (above) {
    frame++;
    above = false;
    above = true;
    frame++;
    //and call it like this on the onClick event of the button
    detect(app.project.activeItem);
    I need to see the entire code and test it in order to see the problem, because it’s not that obvious.
    If you can share your code or file, I could be more explicit.
    Andrei
    My Envato portfolio.
  • Rodrigo Aben
    July 15, 2020 at 5:15 am
    Turns out, Thomas was right. Sorry for the delay guys but your help has been amazing. These are the projects I’ve been able to create with it http://www.abenathar.com
