Activity › Forums › Avid Media Composer › Function similar to clip enable
Posted by Joe Klaw on February 16, 2012 at 4:29 pmIs there a function in Media Composer similar to Final Cut Pros’ clip enable.
Andrew Mckee replied 14 years, 6 months ago 3 Members · 2 Replies -
Shane Ross
February 16, 2012 at 5:39 pmNope. But you can monitor below layers…choose what layer to view. The option in on the timeline on the far left. Just to the right of the V1, V2. The cool thing is that you can choose to not monitor a layer, and it DOESN’T undo your renders, like FCP does.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Andrew Mckee
February 16, 2012 at 9:55 pmYou could create an effect template that has 0 opacity and just apply that to a clip to disable it. Any effect in the Blend catagory should work fine.
Andrew McKee
Editor/Colourist
Avid Certified Instructor – MC5.5
Apple Certified Trainer – FCPX
Pixelwizard.net
