Activity Forums DaVinci Resolve Function Key Mapping
  • Function Key Mapping
    Posted by Vladimir Kucherov on February 2, 2011 at 1:21 am
    For anyone curious, I went through and made a list of what all the Function keys actually do:
    Command + F1 – prefs
    Command + F2 – browse
    Command + F3 – conform
    Command + F4 – color
    in color tab
    F1 – “curves”
    F2 – “qualifier”
    F3 – Format – Output
    F4 – “Window” – circular
    F5 – “WIndow” – linear
    F6 – “Window” – Polygon
    F7 – Nothing
    F8 – Format – Input
    F9 – “Window” – Curve
    F10 – Nothing
    F11 – Key
    Command + F5 – nothing (default, turns on VoiceOver on mac)
    Command + F6 – Viewer
    Command + F7 – Gallery
    Command + F8 – Format
    Command + F9 – Deck
    Command + F10 – Scene (F-key shortcuts stop working while in Scene)
    Command + F11 – Instantly Quits/Crashes resolve without saving (what the heck??)
    Command + F12 – Instantly Quits/Crashes resolve without saving
    Shortcuts I still miss after all these amazing updates:
    Mouse-less toggle of H S L qualifiers
    Cycle through Picker/+/-/+s/-s without mouse
    Also wishing curves window would be larger. For something you want to be able to control very carefully it’s a small window to make small adjustments in.
    Jan Martens replied 15 years ago 5 Members · 4 Replies
  • Darin Wooldridge
    February 2, 2011 at 2:01 am
    Thank you Mr Kucherov!! Nice work.
    NOTE: The comments above are strictly mine, and may not necessarily
    represent those of my employers.
    Darin Wooldridge
    Colorist / Technical Strategist
    818-653-3918-cell
    dwooldridge@mac.com
    check me out at https://www.facebook.com/pages/Davinci-Resolve-Colorist/117363011609028?ref=….
  • Blase Theodore
    February 3, 2011 at 3:18 am
    Sweet thanks Vlad.
    I had never tried the “cmd +” variations.
    FYI I have the HSL’s toggling and +s-s via Quickkeys. (search my novation post of you want the file.)
  • Andi Winter
    February 8, 2011 at 12:55 pm
    hi vladimir!
    it seems on my system none of the F keys work 🙁
    you do mean the ones on the keyboard, right?
    any tipps appreciated!
    andy
  • Jan Martens
    September 8, 2011 at 2:26 am
    Hi Andy!
    Go to SYSTEM PREFERENCES | KEYBOARD | KEYBOARD and check “use all F1, F2, etc. keys as standard function keys”.
    You may also have to disable the F-key shortcuts Expose & Dashboard etc (SYSTEM PREFERENCES | KEYBOARD | KEYBOARD SHORTCUTS).
    Then your keyboard F-keys should work.
    Jan
