Activity Forums Apple Final Cut Pro Legacy Fully rendered sequence “renders” again for edit to tape
  • Fully rendered sequence “renders” again for edit to tape
    Posted by Dan Monro on August 10, 2010 at 3:13 pm
    Outputting a 31 minute sequence using edit to tape. Its a MPEG IMX 525/6 SD timeline, and 90% of the material in it is MPEG IMX 525/6. There are some stills and a few ProRes 422 clips. Everything in the timeline is rendered. Double checked. All blue lines. There are also some Motion templates, and I DO have the setting checked to always use Best Quality wen rendering movies & motion templates using best quality. But I have assumed its doing that the first time I render.
    When I start my edit to tape, I get a dialog box; “writing video”. It happens every time I try to start the output. Takes about 6 minutes to render.
    My questions are: is it re-rendering? writing some sort of cache file? Am I missing something basic in my user prefs?
    This specific system:
    Mac Pro Quad-Core Intel Xeon
    2.93 ghz
    16g ram
    OSX 10.6.4
    FCP 7.0.2
    QT 10 & 7.6.6
    Project:
    MPEG IMX 525/60 (50 mb/s)
    SD output Sony 4 ch Digibeta
    So, I’m hoping I’m missing something simple. Thanks for any insight/advice.
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
    Mac OS X 10.5.8
    GeForce 8600M GT Final Cut Pro 7.0 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
    Dan Monro replied 16 years, 1 month ago 1 Member · 1 Reply
  • Dan Monro
    August 10, 2010 at 3:30 pm
    Noticed a synch issue with the output, and realized my Kona was set to “free run”. Changed it to Ref in (525i29.97) to fix the synch issue, and now the “writing to tape” dialog took about a minute.
    Could it be an issue with synch?
    D
    Dan Monro
    Mac OS X 10.5.8
    – OR –
    Mac OS X 10.6.4
