Activity Forums Adobe Premiere Pro Fully rendered sequence but Fast Colour only ‘works’ when a title is being displayed
  • Fully rendered sequence but Fast Colour only ‘works’ when a title is being displayed
    Posted by Brian Thomas on October 9, 2011 at 10:01 am
    Is this maybe a known problem? I have a four cam multicam AVCHD project: video tracks 1 and 2 have the Fast Colour Corrector applied and video track 2 also has a Rotation of -1 degree applied. No other effects on any of the clips.
    First image is with the color correction appearing as expected. However, by advancing one frame and going beyond the subTitle the Fast Colour effect (reducing red) appears to be forgotten – image 2
    However, all comes out fine on the DVD (using Encore). Am I using something incorrectly or, as I say, is this a known issue?
    Thanks in advance for any guidance.
    PP 5.5.0, FCP 7.0.3 iMac 24 3.06 4GB OSX 10.7 MBP 17″, 2.3 GHz 8GB. Near Geneva, Switzerland
    Brian Thomas replied 14 years, 11 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    October 10, 2011 at 3:27 am
    Go to Sequence > Delete Render Files
    If it’s fine on final render… applying effects, rendering, applying more effects, etc can sometimes “gum up” the preview renders; the preview renders do benefit from being cleared every so often as you work.
    – Angelo Lorenzo
    https://FilmsFor.Us Sell your film and connect with your audience
  • Brian Thomas
    October 10, 2011 at 6:44 am
    That was it! Many thanks – I had never heard of this before but I only started using PPro a couple of months ago 🙂
