Activity › Forums › Apple Final Cut Pro Legacy › full screen white on black text
Posted by Scott Maida on September 6, 2011 at 9:43 pmHow do you create full screen white text on a black background?
Scott Maida replied 14 years, 11 months ago 3 Members · 8 Replies -
Mark Suszko
September 7, 2011 at 4:07 pmNot by zooming; that introduces jaggy aliasing. Select your text and enlarge the font size. There’s a good short tutorial on how to sue character generators in the FCP online manual in your help files.
Stephen Smith
September 7, 2011 at 6:30 pmIn the Viewer click on the little A in the filmstrip icon. Choose Text.
Here is a link to a Final Cut Pro Quick Tips tutorial that will give you a short cut.
Best of luck.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Motion Tutorials
Scott Maida
September 12, 2011 at 10:32 pmThanks for the link.. I’ll check it out tomorrow.. but my biggest issue is not how to get to ‘text’.. but I’m having trouble with getting a full screen of copy as a static and as a scroll. The copy comes out as one long line instead of a column.
Scott Maida
September 12, 2011 at 10:34 pmOnce that is figured out.. and I know it’s simple.. I’ve done it before..
I will also need to get a black back. WHen I delete the video, white appears. -
Stephen Smith
September 13, 2011 at 2:54 pmYou have to hit return to create a new line. I have not tested this but in Motion, if you type the text in the Text program that comes on the Mac it will keep every time you hit the return key or where the next line begins. If you past it from word it becomes one long line of text. Is this what you are after?
Stephen Smith
Scott Maida
September 13, 2011 at 9:01 pmthanks.. that works.. I can scroll or do a full static.
great.now I need to put the text over a black background. Any ideas.
Stephen Smith
September 14, 2011 at 2:53 pmIn FCP I just add a Slug or Matte, Color which defaults to gray so you will need to change it to black. Or you can just put white text in FCP and the back ground defaults to black.
Stephen Smith
Scott Maida
September 14, 2011 at 8:01 pmit defaulted to white but I found what I needed in the manuel and changed it to black.
Still having issues with making a long sentence column correctly on the page.. and does FCP have Spanish or other language features?
I may have to go to internet or word and copy and paste?thanks for all of your help on this!
