Activity Forums Adobe Encore DVD full screen video from play button
  • full screen video from play button
    Posted by David Jelley on October 10, 2005 at 11:10 pm
    Hi, I have never done it but I think it is possible to have a short opening loop of a movie play inside a button (must have read this somewhere) my query is that when the button is pressed to play the movie it enlarges onto the screen from the button and plays on. If possible could instructions on how be posted. thanks in advance. David
    David Jelley replied 20 years, 11 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    October 11, 2005 at 5:03 pm
    If I understand correctly, what you’re asking is: When the button is pressed, how to make it enlarge until it fits the screen.
    To make the motion button itself, check out Encore’s help files, there are instructions there, or you should be able to find a tutorial at one of these sites:
    https://www.wrigleyvideo.com/videotutorial/tut_encore.htm
    https://doogs.sitesled.com/downloads.htm
    To do the other part, where the movie thumbnail zooms up to full size, you need to create a movie of the button enlarging. This is typically referred to as a transition menu.
    Take the menu file (the PSD) into Premiere or After Effects, and just animate the scale and position of the video thumbnail to zoom in as you want. Export that as an AVI, bring it into Encore, and put it in a timeline. In the menu in Encore, set the link for the button to this new timeline. Then set the end action of that timeline to the timeline that you’re actually trying to link to.
    There are a couple of limitations and gotchas with this setup.
    * There is no way for you to control frame sync between the motion menu and the menu transition. It’s just not possible.
    * In order to control frame sync between the menu transition and the actual timeline that you’re linking to, make sure to trim the frames so that the last frame of the transition and the first frame of the timeline are contiguous.
    * Depending on the player you use, there will be a slight pause, and possibly a black screen, when the DVD loads the menu transition and when it loads the timeline. Nothing you can do about that, either.
  • David Jelley
    October 11, 2005 at 10:24 pm
    Thanks for your reply I will look up the help menu and look at the links suggested. I will let you know how I get on thanks again. David
