Activity › Forums › Apple Final Cut Pro Legacy › Full Rez QT Bad on Client’s PC
  • Full Rez QT Bad on Client’s PC
    Posted by Les Duncan on April 11, 2009 at 11:35 pm
    I have a show that I exported as full rez QT from FCP. It looked great on my G5 and my G4. I uploaded it to FTP, the client downloaded and it looked pixilated and out of focus! They were viewing it on a G5 mac. While troubleshooting, I played it on a PC in QT. It also looked bad! Then I tested a QT output I did a year ago on the PC, and it had the same flaws, although it is fine on the Mac. What gives? Thanks for the response.
    Les
    Les Duncan replied 17 years, 5 months ago 3 Members · 3 Replies
  • Dino Vince
    April 13, 2009 at 7:14 pm
    Depends on your export settings? If you’re exporting as NTSC-DV, it’s made to be viewed on a video monitor…it’s that square pixel (computer) vs. rectangular pixel (video) issue. Try exporting a couple of different file types and see what looks best. Good luck!
  • Jason Diebler
    April 14, 2009 at 2:06 pm
    Open the QT (in QT), hit Apple+J, go to Video Track “visual settings” and make sure “high quality” is checked. Then save.
  • Les Duncan
    April 14, 2009 at 5:47 pm
    Thanks, Jason. Problem solved!
    Les Duncan
