Activity Forums DaVinci Resolve Full Res Debayer from F55 raw / low grade hardware
  • Full Res Debayer from F55 raw / low grade hardware
    Posted by Nate Weaver on March 16, 2013 at 11:58 pm
    It appears running full version 9.1.1 on OpenCL hardware that I cannot get a full res debayer from F55 raw material. Per another post I had a month or two ago, my 1GB of video ram precludes it.
    Is there anyway to force full res debayer via command line? Or, another idea, force via command line a CPU debayer?
    The Sony raw viewer only allows DPX or OpenEXR output, so I’m having a devil of a time trying to get some high-quality tests done of the raw. The half-res debayer has aliasing and noise issues.
    I’ve had enough of the Macbook and would jump into something better immediately, but the imminent Mac Pro update has me in a tough spot. Id like to know what’s coming before I blow $2600 on an iMac!
    Nate Weaver
    Director/D.P., Los Angeles
    https://www.nateweaver.net
    Joseph Mastantuono replied 13 years, 5 months ago 4 Members · 4 Replies
  • Eric Hansen
    March 17, 2013 at 4:39 pm
    how about using the Sony software to create the DPX files, then play the DPX files back in Resolve? you’ll need 250-300MB/s to play them back in realtime for HD-size DPX files. but if you’re just looking at individual frame quality, that’s probably fine.
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • Eric Hansen
    March 17, 2013 at 4:42 pm
    btw, we just rented an F55 for the week, and we can’t turn on the raw recording. all the options are ghosted out. we have the AXS-R5 raw recorder and cards. any ideas?
    thanks
    e
    Eric Hansen
  • Ned Soltz
    March 18, 2013 at 2:21 am
    You must put the F55 in CineEI mode. That will activate the AXS-5 recorder.
    Ned Soltz
  • Joseph Mastantuono
    March 18, 2013 at 11:57 pm
    The Abel cinetech blog has a pretty comprehensive video about it…
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
