Activity › Forums › DaVinci Resolve › Full range render
Full range render
Posted by Robin Erard on October 19, 2011 at 5:40 pmHello,
I don’t understand the idea to render in “Legal Video.”
If I receive material for example prores 422 HQ, I grade on my resolve with a calibrated REC709 projector. I specify to work in legally scale in preference tab. And I render it…
At this moment it renders in full range 0-1023. And the only thing I have to specify to the lab for a 35mm print is “DPX REC709 0-1023”. They know how to adjust white and blacks.
Then why this function “render video scale” exists ?
Best
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.chStig Olsen replied 14 years, 11 months ago 6 Members · 7 Replies -
Joseph Owens
October 19, 2011 at 10:21 pm[Robin Erard] “why this function “render video scale” exists ?”
Its for the handful of individuals who grade for broadcast and other tasks that use 64-940.
jPo
You mean “Old Ben”? Ben Kenobi?
Christopher Adams
October 20, 2011 at 2:27 pmSO we should maybe set processing to full and then work in legal scaled then output “legal scaled” setting on more then not for Broadcast at this point?
Does this also clip to legal things like DPX that in the past always output full range data?
CJ -
Stig Olsen
October 20, 2011 at 5:13 pmMaybe this answers some of your questions – https://forums.creativecow.net/readpost/277/10662
Robin Erard
October 20, 2011 at 5:51 pmHello,
If we output in Full range the only thing we have to tell to other softwares is to read the file as REC709. In Nuke we just select REC709 to have the good mapping. Am I right ?
Even in FCP the render in Full range is interpreted as REC709.
That’s why I don’t understand when we need to rend in legally ? Is it when we output on tape ?
I’m very sorry with these bascis questions, before this new option everything was clear in my mind, but this new option disturbs my spirit.
Best
Robin
http://www.robinerard.ch -
Tim Farrell
October 20, 2011 at 9:10 pmAs Joe says it’s for people who want to render “studio RGB” (scaled) instead of “computer RGB” (full range). (eg: render dpx files and have Data Level set to Normally scaled legal video.)
If rendering to YUV codecs like ProRes 422 or DnxHD it’s not relevant because your renders will always scale to 64-940.
Peter Chamberlain
October 21, 2011 at 3:49 amJoseph and Tim are correct. If you have a RGB file type, like DPX, it will usually be in the full range data structure. When you record that full range DPX to tape to make a HD Rec.709 standard video, the DeckLink scales the full range to the video range. Just like the DeckLink does for your Rec.709 monitor.
The new option lets you render the DPX in the video range and this make a HD deliverable without the need to go to tape.
Consider now that on the input side, you have some DPX files in full and some in video range. The clip by clip selection allows you to scale the video range DPX up to the full range used in the Resolve processing and to match all the other files.
The YUV formats are generally in video range and so you may not have considered the above scenarios before as you would not have seen this workflow.
These new features in 8.1 are to give you more flexibility if you need it, but should not change your normal operation if you don’t need them.
Peter -
Stig Olsen
October 21, 2011 at 11:27 amBut, make sure you dont switch the full range vs normal range in the middle of a project, because it influence how you “see” the image on your timeline.
If you want to read 64-940 on your internal scoop, simply add a soft clip lut set to 64-940 on the timeline track. But then, make sure its set to full range for not doubling the effect.
For the Avid workflow…
Resolve works as it should, just render to YUV and the scaling are correct, no matter if you work 0-1023.
The problem is with Avid. Mediacomposer is not a finishing tool, and there is no way to have Avid to read the files correctly when imported back the regular way or with AMA.
Even though the YUV files from Resolve is scaled to legal, Avid will wash out the black levels and increase the highlights. Its just the way it works. The new major Avid-upgrade that is soon comming has not taken this seriosly, so if you want it to look the same in Avid as in Resolve – there is no way as it is today.
