Activity › Forums › Apple Final Cut Pro Legacy › full frame to letterbox
Posted by Russwill on May 30, 2007 at 4:24 pmother than using the filter widescreen is there another way to make a 4×3 full frame into a letterbox without losing the top and bottom of image
Ben Oliver replied 19 years, 4 months ago 5 Members · 5 Replies -
Shane Ross
May 30, 2007 at 4:28 pmHow can you? You are taking a square image and making it rectangular…you have to lose information somehow. Just like PAN AND SCAN chops off the sides of a widescreen image, to make 4:3 into letterboxed 16:9, you need to chop off the top and bottom.
And this is something you need to plan for.
Shane
Littlefrog Post
http://www.lfhd.net -
Richard Martz
May 30, 2007 at 4:29 pmThat is what letterbox is. You can’t magically invent additional areas of the screen that weren’t captured.
Richard Martz
MagicMartz MediaFinal Cut Pro HD
Kona LH
After Effects
PhotoShop
Illustrator
Lots of other Fun Stuff! -
Michael Sacci
May 30, 2007 at 4:37 pmThis reminds me of a time I worked at a camera store and a customer wanted the exact same image in an 8×10 as her 4×6 and I told her it would crop some off the top and bottom, she would not have any of that and said she wanted it to contain the exact same amount of image, I told her to do that it would distort the image or she could have that if she went to a 8×12. She shook her head and said “I thought you guys were professional.”
Ben Oliver
May 30, 2007 at 4:43 pmwhen starting a project i decide what my output will be to start with, and go from there. I do a lot of documentaries, and sometimes that means mixing formats. you have to find a way to stylistically make it all work.
pretty much tho, coing from 4×3 to 16×9, you’ll have room to work with the cropping. just dragginthe filter on, won’t do much, you’ll have to play around with it to get the correct frame.
heck, you can basically reframe those shots in your movie to your specifications. its kind of a good thing, sometimes.
