Activity Forums DaVinci Resolve Full Database Backup
  • Full Database Backup
    Posted by Vladimir Kucherov on November 9, 2010 at 1:01 am
    Hi guys,
    Going to be doing a system reinstall on my mac and I’m trying to figure out how to do a full database backup. Is that possible? I know I can do backups of my projects, but can I just backup my full database with all the users, settings, stills, in one go?
    Kevin Cannon replied 15 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Ola Haldor voll
    November 9, 2010 at 8:29 am
    Good question – I’m interested as well.
  • Michael Cinquin
    November 9, 2010 at 12:39 pm
    open the Terminal and :
    * to save the database on your Desktop, with a name of davinci_currentdate.tar
    /Library/PostgreSQL/8.4/pgAdmin3.app/Contents/SharedSupport/pg_dump -h localhost -U postgres resolve --blobs -f ~/Desktop/davinci_`date "+%y_%m_%d_%H_%M"`.tar --format=custom --verbose
    * to restore the database from an archive (WARNING : current database will be erased)
    /Library/PostgreSQL/8.4/pgAdmin3.app/Contents/SharedSupport/pg_restore -h localhost -U postgres --single-transaction --clean --dbname=resolve FULLPATH_OF_THE_ARCHIVE
    use at your own risks ! the password that the terminal will ask is that of the PostgreSQL database : DaVinci
    I use it here successfully up to now
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
  • Rohit Gupta
    November 9, 2010 at 2:17 pm
    The pgAdmin tool has a nice GUI to backup/restore your databases. This is included with the Resolve install (search in spotlight – pgAdmin).
    When backing up, remember to add the .backup extension to the filename, else you will have to rename it in Finder.
    When restoring, you will have to create a new database, and restore to that database to avoid over-writing the current database.
    Hope this helps!
    Regards,
    Rohit
  • Vladimir Kucherov
    November 9, 2010 at 3:25 pm
    Perfect! Thank you Rohit and Michael.
  • Ola Haldor voll
    November 22, 2010 at 3:50 pm
    Hmm where exactly am I supposed to find the file or database to backup? I opened pgAdmin and it says there’s no servers.
    Nor do I understand how I can open one.
  • Guilherme Ramalho
    November 27, 2010 at 6:31 pm
    Hi Ola,
    Did you found out how to do the datadase backup ?
  • Ola Haldor voll
    November 27, 2010 at 6:52 pm
    Nope.
  • Kevin Cannon
    December 12, 2010 at 7:41 pm
    I’m not 100% sure here, but nobody else seems to be chiming in…
    It looks like you open pgadmin, then “add a connection to a server,” you’ll be prompted for a name (perhaps “resolve”) a host, port, username, password (case sensitive)…
    Most of which can be found in the login screen>database manager>connect screen.
    Then you’ll be connected to your resolve server and can select it and access the “backup” tool, which the documentation says is simply a GUI for the pgdump tool.
    It generated a 1 GB file for me, I haven’t confirmed that it worked.
