Activity Forums Web Design (WordPress, Joomla, etc.) FTP and web address questions
  • Abraham Chaffin
    October 19, 2007 at 2:02 pm
    [Scott Jensen] “www.mywebsite.com/photofolder”
    Probably the last forward slash. Depending on the server it may or may not interpret this as a folder and may or may not show you the folder contents if there is no index file.
    http://www.mywebsite.com/photofolder/
    Generally – the first thing the server will do when you put in this address is look for an index file in the folder. If one is there it will execute the index file. If not, based on the configuration, it will either give you a 404 or show you the folder contents.
    Abraham
  • Justin Junda
    October 19, 2007 at 9:10 pm
    abraham is right but regardless I dont think this wouldnt be the best way to do something like that. You should either A create a gallery using dreamweaver, photoshop flash etc… or simply just zip all the pictures up and place them on the server. ex. http://www.mywebsite.com/pictures.zip this way the will just download to the clients machine and they will be able to view them all in the viewer slideshow as opposed to one image at a time.
