Activity › Forums › Adobe After Effects › fter Effects CS3 YUV-RGB conversion : total mess
  • fter Effects CS3 YUV-RGB conversion : total mess
    Posted by David Coiffier on September 8, 2008 at 9:28 pm
    Hello all,
    Should be a point many times discussed, but not solved : YUV to RGB conversions done in AE8.
    I am videographist, I work on Mac, and I’m something like 20 years experience. I tell you this to avoid usual recommandations and useless pre-checkups…
    I was recently on 10.4 OS with a quad G5, and I just switched to MacPro 8 core, running 10.5 OS.
    My video board is a Kona3, that’s now exclusively with Pal HD IO (1920*1080 YUV 10 bit).
    As 10bit uncompressed is just a pain in the ass, I decided to use 10bit HQ ProRes, which works like a charm, at least until I have to go out and come back to FCP…
    From what I saw, uncompressed 10bit YUV is correctly interpreted as a footage in AE8. There’s a slight gamma shift when previewing AE comp thru Kona3 preview, but once back in FCP, gamma shift is just gone.
    BUT ProRes is totally misinterpreted, and huge color shifts are occuring, with no easy or correct way to fix it. If some of you wanna make a short test, I can recommand exporting FCP bars, as ProRes QT, and import into AE. Look at what you now have : total crap.
    I’ve been playing with color management, Rec709 simulation on/off, footage interpretation as Rec709 on/off, only slight differences occur, and for sure nothing related to signal shifts I can see…
    So what the f**k ?
    Is it a known problem at Adobe ? As many post companies are actually switching to HD, buying new computers, new video boards, looking for new consistent HD workflows, is Adobe aware of the trouble this issue can cause ?
    That said, is there a way to fix this by hand ?
    I know there’s a famous “interpretation rules 802” text file, supposed to contain rules to interpret many formats, but I can’t figure out what to do in it…
    Anyone with such knowledge around here ?
    Am I alone with this issue ?
    Thanx for your help
    David
    Andrew Toschi replied 17 years, 9 months ago 4 Members · 5 Replies
  • Chris Wright
    September 8, 2008 at 10:17 pm
    You’re in luck, there’s a fix for both the prorez and the Kona
    https://sites.google.com/site/fcpaegammaissue/
    further reading of FCP color problems can be found here
    https://forums.creativecow.net/thread/2/919924
  • Jack Tunnicliffe
    September 19, 2008 at 2:49 am
    You need to use the AJA v210 codec. This was developed specifically for round trips from FCP to AE and back. We replace single frames like when we are painting dust and there cannot be a gamma shift. Failure to use this codec will result in gamma shifts. AJA did a masterful job of creating this codec for we AE users and round trips are mathematically identical.
  • David Coiffier
    September 19, 2008 at 8:00 am
    Thanx for the info Jack!
    I will test asap this v210 codec!
  • Jack Tunnicliffe
    September 19, 2008 at 3:06 pm
    I’m sure you’ll get good results. It was developed for exactly this purpose.
  • Andrew Toschi
    December 26, 2008 at 11:24 pm
    I have the same problem and I’m doing a test render now.
