Activity Forums Adobe Premiere Pro FSI monitor 8-bit, editing 10-bit
  • Kris Merkel
    July 23, 2013 at 2:49 pm
    Hi Matt,
    All of those units are 8 bit panels that are capable of reproducing 16.7 million colors. A 10 Bit panel is capable of reproducing 1.073 Billion colors. You have to be careful when looking at marketing terms. The JVC notes 10 bit color processing and that is pretty much the standard with current available monitors but the panel bit depth is still 8 bit. The FSI is capable of 12 bit signal processing, which really nothing in that price range comes close to.
    What you will see regarding the difference of looking at a 10bit panel vs and 8 bit panel is a 10 bit panel will give you smoother gradients where you will see subtle banding on 8 bit panels. Really for your budget, you will be looking at a monitor with an 8 bit panel and then you have to decide what really makes one of these units stand out over the rest, color fidelity, resolution, scopes and meters, 3G SDI level A and B for advanced formats, advanced pro features, weight, power consumption and how much repair cost are and down time if you have to send a unit in for service. Also if you are working on material destined for Broadcast/ web a monitor with an 8 bit panel will be perfect as all broadcast is 8 bit anyway.
    You can compare the FSI BM210 to the LM-2140W here https://www.flandersscientific.com/index/bm210.php#prettyPhoto/20/
    Working in REC709 the color fidelity of both those units will be identical.
    Hope that helps answer some of your questions.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Matt Campbell
    July 23, 2013 at 3:28 pm
    Helps very much, thanks. I was just reading a post I think you were a part of, but could be wrong. Does Premiere even output 10-bit. I thought I read somewhere that it only outputs 8-bit signal anyway.
    The specs on the FSI BM210 does show 10-bit processing for SMPTE-425M-AB, but obviously will only show 8-bit. So assuming I could output a 10-bit signal from Premiere and through the Decklink Studio, that panel would only show an 8-bit signal anyway. I think I can live with this, since the majority of our work is online anyway. Just want a good panel with good color for reference and light grading. Everyone raves about the FSI, so I’m really leaning towards them.
    OSX 10.7.5 with a 3.39 Ghz Intel Core i7 on a built up Hackintosh
    16 GB of RAM with OSX on SSD, (2) internal HDDs RAID’d 1 for project files and External RAID 5 for all project assets (media, GFX, stills, etc.)
  • Kris Merkel
    July 23, 2013 at 4:33 pm
    Video output Bit Depth from PrPro is debatable and I for one have measured 10bit YUV signals via PrPro -> IOXT -> FSI. Some others stand by the statement that it is only 8 bit. Someone from Adobe might be able to shed more light on this. I do know that the AJA control panel is processing the signal as 10bit YUV and sending that to the monitor. Like I said before at $2500 level you will only be looking at units with 8bit panels from any of the popular manufacturers.
    The panel in the BM210 and LM-2140W are the same panel. The BM210 is capable of working in multiple colorspaces as well as importing user generated 3D Calibration and Look LUTs, accepting Dual-Link signals, and has the ability to display 2 live signals side by side where the LM-2140W works only in REC709, and has switched SDI inputs so Only one SDI input can be active at one time.
    As I mentioned before, performance with regards to Color Fidelity will be identical on either of the units working in REC709
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Matt Campbell
    July 23, 2013 at 6:04 pm
    Thank you.
