Activity Forums Sony Cameras FS700R crop factor with FF lens
  • FS700R crop factor with FF lens
    Posted by Enrique Bartolo on November 7, 2016 at 9:41 pm
    Hello, I have a Zeiss Loxia 35mm E-mount Full Frame lens and I want to use it with a Fs700r, but the fs700r has a super 35 sensor and it would give a crop factor of 1.5 I believe. Which means it’ll turn my 35mm into a 52mm. Therefore, I’m assuming the 52mm crop will happen if aspc mode is on. So will it still have notciable vignette if aspc mode is off even though the lens is bigger than the sensor?
    I also heard that the fs700r has a full frame mode?
    Gabe Strong replied 9 years, 9 months ago 2 Members · 1 Reply
  • Gabe Strong
    December 16, 2016 at 2:48 am
    First……the FS700 will NOT, NOT, NOT ‘turn a 35mm into a 52mm.’ Any 35mm lens,
    (no matter if it is a APSC 35mm or a FF 35mm) will look the exact same on
    a FS700. The only rationale behind ‘crop factor’ is to relate all lenses to
    the field of view of a full frame camera. Which you don’t need to do, unless you
    are a 5D shooter. So a 35mm lens on a FS700 will look similar to a 52mm lens on a 5D,
    but any 35mm lens will look the same on the FS700 (with one exception noted below.)
    There is no ‘APSC crop mode’ on the FS700…..it is by nature a Super 35 chip, which is
    basically APSC sized. You can’t ‘turn this crop off’, because this is the native size of the sensor.
    *Exception
    You can use a Speedbooster/focal reducer which will allow you to use full frame lenses
    on the FS700. This adapter is ‘sort of’ the opposite of the ‘doubler’ which used to be on many
    news broadcast cameras. The doubler gave you twice the reach, at the expense of losing a stop
    of light. The Speedbooster, gives you a wider field of view….and you gain a stop. What this basically
    means, is that you can use a full frame lens on a FS700…..and get the field of view that you would get
    on the full frame camera, plus you get an extra stop. If you try to use an APSC lens on a Speedbooster,
    you would get a vignette, but not the other way around.
    Gabe Strong
    G-Force Productions
    http://www.gforcevideo.com
