Activity › Forums › Sony Cameras › FS7 White Balance
  • FS7 White Balance
    Posted by John Treffer on October 30, 2015 at 10:38 pm
    I am shooting with an FS7 in CineEI mode and the Paint options, especially the white balance is greyed out. The standard options seem to be locked to 3200K, 4300K and 5500K.
    Is there a way to set custom white balance, while staying in Cine EI mode?
    John Treffer replied 10 years, 10 months ago 1 Member · 1 Reply
  • John Treffer
    November 3, 2015 at 2:01 pm
    I read the long post here: https://community.sony.com/t5/FS7/Cine-EI-White-Balance-Presets/td-p/475930
    which really has some nice info (between the cockfighting).
    Unfortunately it seems to confirm the problem that there is no way to set white balance other than the Default presets. And it seems that there is no easy way in resolve to correct white balance.
    My workflow is to shoot with the closest WB preset, and do a pre-grade in resolve with LUT and White Blance using seperate RGB curves/gain before it goes to the editor.
    If the white balance issue is solved and the editor can use LUT’s it would save the time of the pregrade and all the extra data involved.
    If people have ideas on better workflows to deal with the situation I’m curious to hear them.
