Activity Forums Sony Cameras FS7 Shutter
  • FS7 Shutter
    Posted by Steve Ford on July 6, 2021 at 7:44 pm
    From time to time I shoot under fluorescent lighting which I augment with additional LED lights. In post I notice what appears to almost be scan lines when I shuttle through the footage. I am assuming that is due to the cycle speed of the fluorescent lights. Have you run into this issue and if so, what was your solution?
    Arun Naskar replied 4 years, 6 months ago 4 Members · 4 Replies
  • Jeremy Garchow
    July 6, 2021 at 8:03 pm
    Are you sure that’s not rolling shutter artifacts? Is it only visible when scanning footage or do you see it when you play back in normal speed?
  • Steve Ford
    July 6, 2021 at 9:43 pm
    I see it more when scanning the footage, when I play it back in normal speed, it is there but not very obvious but still there. I have learned about the 60hz cycle speed so I may try setting the shutter to 60 but I may also trying to shoot and 60fps too. Thoughts?
  • Blaise Douros
    August 5, 2021 at 9:44 pm
    This is an oldish thread, but I see no answers, so I’m going to do a quick one.
    This artifact can be caused by fluorescents, in which case the answer is to shoot in ECS (Extended Clear Scan) to minimize the effect: https://www.manualslib.com/manual/860623/Sony-Pxw-Fs7.html?page=61
    Faster shutter speeds will actually make this harder, so 23.976 or 29.97 is actually better in this case. But still turn on ECS.
    It is more likely that it’s being caused by your LED lights. LEDs often use Pulse Width Modulation to dim the lights, and there is no industry standard for the frequency. If your LEDs were cheap, then it’s highly likely that this is the case. A similar thread from awhile back:
    https://creativecow.net/forums/thread/lights-for-dslr-video/#post-2005103
    If you find that it’s your LEDs, one solution might be to turn your LEDs on full blast, so they are hopefully not pulsing, and just move ’em back.
    Lights for DSLR Video
  • Arun Naskar
    February 25, 2022 at 4:49 pm
    Hi can you help me that what is the best camera at reasonable cost?
