Activity › Forums › Adobe Premiere Pro › FS7 4k proxy files – transcoding with audio in mind
  • FS7 4k proxy files – transcoding with audio in mind
    Posted by David Busse on May 1, 2015 at 5:02 pm
    I need to transcode files for my system to work well with 4k from the FS7 shot in Cine El. The audio from the FS7 has 8 channels and I can’t figure out how to maintain the 8 channels of audio upon transcoding. The transcoding I’ve done gives me 2 channels of audio that are mixed. In the least I need two separate channels of audio after transcoding, but preferably to maintain all 8. FYI I don’t have issues reconnecting media, just maintaining the audio files.
    I’ve thought of a work around, but it requires more rendering time that I would prefer to avoid…work around is just to export audio as a WAV once it is in my timeline and then drag it in.
    David Busse replied 11 years, 5 months ago 2 Members · 4 Replies
  • Trent Happel
    May 1, 2015 at 5:22 pm
    Was your Sequence master audio set to Multichannel audio tracks? Also, which export format are you trying? Some are limited in the types of audio channel support.
    Here’s a link that might be helpful:
    https://blogs.adobe.com/VideoRoad/2015/02/multichannel-audio-in-premiere-pro.html
    Trent Happel
    Adobe
    Premiere Pro
  • David Busse
    May 1, 2015 at 5:43 pm
    When you say Sequence master audio are you referring to the settings in “Sequence – Sequence Settings…”?
    I’m exporting to ProRes Proxy. Any other suggestions for good proxy formats?
    Thanks for the link, I’ll check it out.
  • Trent Happel
    May 1, 2015 at 6:24 pm
    When you create a Sequence, select the Tracks tab. Under the Audio section, you will see Master: with a drop down menu. Select MultiChannel from this menu. More details are in the link.
    As far as proxy formats, it usually comes down to desired parameters (frame size, frame rate, compression quality, etc.) and does it perform well on your system. From there, it’s personal preference. ProRes works well on Macs. DNxHD is popular for cross-platform. Others stay native and lower the Playback Resolution and Paused Resolution for better performance.
    Trent Happel
    Adobe
    Premiere Pro
  • David Busse
    May 5, 2015 at 4:31 pm
    Just reviewed the article. That is exactly what I needed! Thanks Trent
