Activity Forums Panasonic Cameras FS-100 recombine QT clips
  • FS-100 recombine QT clips
    Posted by Raven Plenty on February 26, 2009 at 11:04 pm
    I am wondering if there is a simple way to recombine long QT clips into single files. The Firestore limit’s clips to 1.9GB chunks, so a 6 minute clip is spread over 3-4 different QT files. I know that when using P2 format, they are recombined in the Log & Transfer process…can the same be done with QT clip fragments?
    Raven Plenty replied 17 years, 6 months ago 2 Members · 4 Replies
  • Christopher Wright
    March 1, 2009 at 8:39 pm
    Either Render all the clips into a single file or just nest the clips into a new comp. Either way is a quick and easy way to do what you are asking.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows Vista Adobe Studio CS4, Vegas 8.0, Lightwave 9.3, Sound Forge 9, Acid Pro 7, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
  • Raven Plenty
    March 2, 2009 at 4:13 pm
    Thanks Christopher, that sounds promising, but…
    “Render all the clips into a single file” – How do I do that?
    “nest the clips into a new comp” – What’s a “new comp”? Do you mean: make a nested sequence?
    March 2, 2009 at 8:45 pm
    You simply drag all your clips on the timeline and select Render>QT movie (NOT QT conversion), current settings. Or Nest your sequence. I prefer the latter because then you still have control of all the separate clips.
  • Raven Plenty
    March 2, 2009 at 10:40 pm
    Very well. I wonder why FAT32 was chosen for the FS-100, since it seems slightly awkward having all these 1.9GB chunks. Surely there was a good reason…
    Should we decide to Render > QT … um… where is that option? I can’t find it in any menus, and can’t find anything about that in the manual either, it’s all about rendering effects etc. Also, does that recompress the footage?
    Many thanks!
