Activity Forums Panasonic Cameras FS-100 Footage Won’t Show in L&T
  • FS-100 Footage Won’t Show in L&T
    Posted by Raven Plenty on February 25, 2009 at 6:00 pm
    Hi, we’ve recently acquired an HVX with FS-100. Still ramping up on the learning curve. We’ve discovered that due the the FAT32 disk format, clips are broken into 1.9GB chunks. Is there any way around that? I was thinking that perhaps if we use Log & Transfer, the clips can be imported as whole intact clips. However, our footage is not showing up in L&T when we point it to the footage folder on FS-100. We have been shooting 1080i in QuickTime format. Does L&T only recognize P2 format?
    Any thoughts or suggestions? Thanks!
    Raven Plenty replied 17 years, 6 months ago 2 Members · 4 Replies
  • Shane Ross
    February 25, 2009 at 10:42 pm
    [Raven Plenty] “We have been shooting 1080i in QuickTime format. Does L&T only recognize P2 format?”
    Yup. If you shot in the QT format, simply FILE>IMPORT your footage.
    Shane
  • Raven Plenty
    February 26, 2009 at 8:14 pm
    Great, thanks Shane. However, the footage isn’t showing up there either. In fact we’ve shot test footage in both P2 and QT format, and neither clips are working via L&T or Import. We are getting an “invalid directory structure” error in both cases. It’s an 8-core Mac Pro running Leopard, with FCP Studio 2.
  • Shane Ross
    February 26, 2009 at 9:23 pm
    [Raven Plenty] “We are getting an “invalid directory structure” error in both cases.”
    Well, I have ZERO experience with the Firestore, but I know if you shoot as P2 and not QT, that you need to use the option PREPARE FOR P2 so that it will make the proper file structure. Have you done that?
    Shane
  • Raven Plenty
    February 26, 2009 at 10:47 pm
    That did it, thanks! FYI, on the FS-100 it’s Utilities > Organize P2.
