Activity Forums Panasonic Cameras FS-100 Bad Dropout and timecode mismatch with DV tape
  • FS-100 Bad Dropout and timecode mismatch with DV tape
    Posted by Steve Voyk on May 25, 2007 at 1:52 pm
    Hi guys,
    After a few weeks of practicing with my PAL FS-100(ver.3.0) and HVX202, I did my first real job today. It was fairly easy as it involved shooting 6 different interviews of between 3-5 minutes each.
    I opted to shoot DV resolution so that I could have a simultaneous DV tape backup incase I had any issues with the FS-100. I’m glad I did!!
    After importing into Avid Express Pro 5.5.3, all my clips were fine except that I came across a bad dropout on both video and audio tracks on my second interview on the FS-100 recording. It was 3 frames in duration and the video image was broken up with multiple red/green pixels thrown in whilst the audio on both channels just gave a loud, short splat of white noise. That was problem #1.
    So being an experienced editor, I figured I’d just look at the source timecode and then go and capture that same timecode from DV tape. After capturing, I matched the two source timecodes together and performed an overwrite edit. Immediately, it was out of sync.
    Through slip-trimming I was able to get it back into sync… but the source timecode on the DV tape was 34 frames (01sec 08frm in PAL) EARLIER than the source timecode on the FS-100. Hmmmm.. major issue!!
    I know that with high end VTR’s you can have play/delay settings which affet the timecode/video sync relationship, but I don’t believe this is the case for capturing from DV tape from the camera, hence I believe there is a 34 frame delay in the timecode being recorded to the FS-100 when simultaneously recording to DV tape as well.
    I’m emailing the Focus support guys but was wondering if anyone else has seen (a) dropout problems in the middle of recordings, as this is inexcusable and (b) if anyone had noticed the timecode delay, although I imagine not many people have had to do frame accurate sync edits between the DV tape and FS-100 hence it would not be an easy thing to notice.
    Appreciate any feedback.
    Regards,
    Steve
    voutique
    Perth Australia
    Steve Voyk replied 19 years, 3 months ago 3 Members · 3 Replies
  • Shawn Alyasiri
    May 25, 2007 at 10:34 pm
    As I recall, I ran into a similar (if not identical) glitch a few weeks ago with the FS100 v3 and the HPX2000 in 1080 60i. I don’t recall that the audio was affected, but the video was definitely digital garbage. I went to the same place on the P2 footage (I didn’t check the timecode – just found it quickly visually) and the P2 was fine.
    FS100 was mounted on the back of the camera (via anton bauer mounting system) with a short 18″ firewire cable. The FS moves with the camera – so there’s no long cable, firewire unplugged scenarios…
    Sounds like there may be a ghost in the new FS100 – but overall, my experiences with them have been good overall (including SD recordings with the SPX800).
    Give them a call – they answer the phone these days. Please post back with anything you find out.
    Thanks very much.
  • Christopher Wright
    May 26, 2007 at 5:42 pm
    Can’t help you out with this one! I’ve never bothered to use the FS-100 if I was shooting to mini-DV tape. I have only used the 720p, 720 pn, and 1080i HD modes and have never had a problem on the two I own!
  • Steve Voyk
    May 27, 2007 at 8:37 am
    Hi guys,
    Just an update.. after doing more QC, I came upon another dropout in another interview, so two dropouts on two separate recordings.
    The FS-100 was sitting on the desk, no vibration and the firewire cable was not moving. Interesting also, is that the two shots had different timecode offsets.. first was 34 frames, second was 18 frames… weird.
    I am talking with Focus support.. will update if I find out anything.
