Activity Forums Apple Final Cut Pro Legacy Frustrating problem about subtitle
  • Frustrating problem about subtitle
    Posted by George Roberson on July 27, 2014 at 6:39 am
    I imported XML file into FCP, but I need change all the fonts from white to yellow. How to do it? I can change one by one, but there is like 1000 works to change one by one. Is there any way to change it as a group?
    I went back to subtitle edit, couldn’t change it there.
    please help!
    george
    George Roberson replied 12 years, 1 month ago 2 Members · 5 Replies
  • George Roberson
    July 27, 2014 at 7:17 am
    this is killing me. I have 800 subtitles, do i need to change it one by one to a differnt font size and color?
  • Nick Meyers
    July 27, 2014 at 8:25 am
    you cant batch modify text generators in FCP
    there is an app you can use: Title Exchange Pro
    or you can do a find & replace in the XML file for the attributes for colour & size.
    create one subtitle the way you like it, place it in a new timeline and export an XML.
    open that XML in text edit, or similar and find the appropriate attributes. (size = xx for instance)
    then open the original XML in text edit, and do a find / replace. (size = xx to size = yy)
    should work!
    nick
  • George Roberson
    July 28, 2014 at 4:39 am
    Thanks! I think I am just gonna keep the default color (white).
  • Nick Meyers
    July 28, 2014 at 7:02 am
    you can cheat the colour in.
    make sure you have all your subtitles text generators on one track
    on a track above that lay some colour.
    right click on the colour, and change it;s composite mode to Travel Matte – Luma.
    if you need drop shadow, then you need to create a duplicate layer of the text generator.
    so in the basic form you’d have:
    V1= image
    V2 = text (will keep hte drop shadow)
    V3 = text (will lose drop shadow, but adopt colour from V4)
    V4 = colour
    of course you can use the wireframe to alter the size of the subs, but if you make them too large they’ll go a bit soft.
    nick
  • George Roberson
    July 28, 2014 at 7:40 pm
    Thanks man. Too much for me to handle. Appreciate your input…
