Activity › Forums › Adobe After Effects › Frozen frames of Footage Error
  • Graham Quince
    June 13, 2020 at 12:42 pm
    Really difficult to tell from the clips, but i see what you mean.
    I did notice that the original footage is 32fps and your capture is 60fps.
    You’re using time remapping, but what are the 3D cameras doing?
    http://www.YouTube.com/ShiveringCactus – After Effects Tutorials
  • Richard Garabedain
    June 18, 2020 at 6:35 pm
    it could be that frame rate difference…But i have also had this problem before…When you create a new camera and you move its origin, this tends to happen. for some reason the cameras origin must start at 00:00:00..and once moved its very hard to tell where the try origin really is
