Activity Forums Sony Cameras Frosty weather and Cinealta
  • Frosty weather and Cinealta
    Posted by Alexgoluikh on October 29, 2005 at 12:58 pm
    Can You advice me the optimal Fan mode on CineAlta F900 on frosty (-10, -15 C) weather? After working about 6 hours, camera switched off spontaneously and doesn’t switchs on. Symptoms – panel with timecode does-not switches on, in viewfinder shown only grey area. No picture on control monitor.
    Thank’s for any advice.
    Roboday replied 20 years, 10 months ago 4 Members · 3 Replies
  • Steve Wargo
    October 29, 2005 at 6:05 pm
    Sounds like the DC to DC converter. If you are a technician, remove all power, pull the large cover off of the tape side of the camcorder, look near the rear of the camera and you will see a shiny metal box. See if it is loose. If so or even if not, unplug it and plug it back in. Sony did not build in a holder for this item and it could have shaken loose. Make sure it’s in it’s slot securely and repower the camera.
    This has happened to me twice. I now have a rubber pad inside the cover which keeps light pressure on the converter.
    There are also a dozen (14) boards on the switch side of the camera that could have come loose, but not likely.
    If it’s a rental camera, call the emergency number that came with the unit.
    Also, ALWAYS turn the power switch OFF before changing batteries or power connections. It has a built in buffer which prevents power surges.
    Good luck
    Steve Wargo
  • Michael Brennan
    October 30, 2005 at 6:31 pm
    Did you hear the fan run at high speed before it switched off?
    By and large HD cameras getting too cold hasn’t been a problem so far, so I would look for the more everyday issues as Steve has indcated.
    Lets us know how you get on.
    Mike Brennan
  • Roboday
    November 14, 2005 at 4:46 pm
    It may not be the same thing BUT, today when I went outside with the HVR Z1E, i had a battery that said around 70mins time left…was outside for a few mins and it just shut down and wouldn’t start up again…swapped the battery and it was fine.
    get a scarf for the batteries 🙂
