Activity Forums VEGAS Pro from Wikipedia… Vegas !
  • from Wikipedia… Vegas !
    Posted by Enrique Orozco on January 23, 2011 at 3:10 pm
    Vegas does not require any specialized hardware to run properly, allowing it to operate on almost any standard Windows computer across a broad range of hardware.
    In areas of compositing and motion graphics Vegas provides a broad tool set including 3D track motion compositing with control over z-depth, and spatial arrangement of visual planes including plane intersection. Unfortunately keyframing of simple 2D motion lacks bezier adjustments and multiple keyframed smooth motion is marred by slowdowns or hesitations at each keyframe.
    Much of the visual effects processing in Vegas follows an audio-like paradigm. Effects can be applied at any stage of the visual signal flow — event level, track level and output level effects, much like reverb, delay and flange audio effects are applied in a digital audio system, like Pro Tools, Cubase or Sonar. Master output effects can also be controlled and manipulated over time by the use of Master Bus track automation envelopes.
    With version 8.0, Vegas now reads MJPEG AVIs (usually from “video” setting on digital still cameras). (With prior versions of the software, installing an MJPEG codec sometimes fixed the problem.) Third-party codecs are supported but it can be difficult to see which codec is being used to play back an AVI. Some of Vegas’s codecs are ‘native’ or built-in.
    Vegas features integration with 24p DV. It is also one of the few NLEs which can convert other formats to 24p (or any format to any other format) without any kind of a plugin or third-party application support and is the only pro NLE that allows for multiple instances of the application to be opened simultaneously. Clips and sequences can be copied and pasted between instances of Vegas with ease. Moreover, one instance can be rendering a sequence in the background while the user continues to edit in a different instance of Vegas in the foreground. It also comes with a green screen feature where you can merge pictures into each other.
    Released on September 10, 2007, the Vegas Pro collection combines Vegas Pro 8.0, DVD Architect Pro 4.5, and Dolby Digital AC-3 encoding software to offer an integrated environment for all phases of professional video, audio, DVD, and broadcast production. These tools let the user edit and process DV, AVCHD, HDV, SD/HD-SDI, and all XDCAM formats in real time, fine-tune audio with precision, and author surround sound, dual-layer DVDs.
    * Vegas was the second NLE that allowed users to put a variety of formats on the timeline and just edit them. Other NLEs would require the user to render or “conform” these down to a single format. Vegas Video 1.0 had this in 2000. Final Cut Pro got this feature in 2007 with FCP 6.
    * In 2003 when the 4.0b update was released, Vegas users got HD editing support and 24p support for free.
    * Vegas was the first NLE with “serious” audio tools, such as integrated 5.1 surround mixing, 24-bit/192 kHz audio support, and ASIO driver support.
    Vegas started life as an audio-only tool with particular focus on rescaling and resampling audio, making it arguably a leader in its category with substantially more sophisticated audio tools than any other NLE.
    Vegas was among the first NLEs to embrace HDV support both as native TS files and through lossless transcoding tools such as Cineform Connect HD.
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Enrique Orozco replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
