Activity Forums DVD Authoring from VHS to DVD but nothing on DVD?
  • from VHS to DVD but nothing on DVD?
    Posted by Paolo Drusi on September 17, 2018 at 1:51 pm
    Hello,
    I’ve been transferring some VHS tapes onto DVDS linking the VHS player and the DVD recorder via scart. All looked ok, I can see all the videos (one for each tape, several in 1 dvd) on the disc when I play it back on the DVD player/recorder, but the disc seems empty when I try to read it on a computer. I’ve tried using VLC browsing the disc.
    The final aim is to have the VHS videos as computer files.
    Any suggestions on why I can’t access the videos from a computer?
    Thank you
    Paolo
    Paolo Drusi replied 7 years, 12 months ago 2 Members · 4 Replies
  • Jeff Pulera
    September 18, 2018 at 6:47 pm
    With the stand-alone DVD recording appliances, you must FINALIZE the disc before it will work in other players. Please check documentation for your recorder. This is because you might record some video now, and then some more later, and the disc must be properly closed up once you are all done, otherwise the disc is still open to writing and to other players, does not look like a proper DVD when not finalized.
    Jeff
    Jeff Pulera
    Safe Harbor Computers
  • Paolo Drusi
    September 18, 2018 at 6:54 pm
    ah! Very interesting, I forgot about that haha, too long ago!
    Will there be a way to do so as a function of the DVD recorder?
    Thanks very much for your help, much appreciated!
  • Jeff Pulera
    September 18, 2018 at 7:03 pm
    Yes, that is why I said to check recorder documentation. Might be a button on remote, or you may have to access a certain on-screen menu to select FINALIZE option, I don’t know which model you might have. But that should be the answer to resolve the problem.
    Jeff Pulera
  • Paolo Drusi
    September 18, 2018 at 7:41 pm
    That’s great thanks so much!
    P
