Activity Forums AJA Video Systems from the Apple website on drop frames and LCD monitors !
  • from the Apple website on drop frames and LCD monitors !
    Posted by Bob Zelin on January 11, 2006 at 3:16 am
    Final Cut Pro: 60 Hz Monitor Refresh Rate Interferes With Playback
    This article describes how a 60 Hz monitor refresh rate can interfere with playback in Final Cut Pro.
    While playing clips in Final Cut Pro, you may notice dropped frames if the monitor is set to 60 Hz. To avoid this, be sure to set your monitor to a refresh rate above 60 Hz using either the Monitors control panel or the Monitor Resolution control strip module.
    When setting a new refresh rate, 75 Hz is acceptable, but 85 Hz provides the best playback performance.
    WHO KNEW !!!
    Bob Zelin
    Ron Thompson replied 20 years, 7 months ago 5 Members · 5 Replies
  • Ron Thompson
    January 11, 2006 at 6:16 am
    Interesting…. I have two Dell 2001FP monitors set to 1600X1200 @ 60Hz. The option to change to 75Hz is greyed out.
    I don’t have any issue here, but its an interesting tidbit.
    Ron
  • Mark Maness
    January 12, 2006 at 5:25 pm
    Yeah… its kinda funny, isn’t it? I didn’t think you can set the refresh rate on a LCD panel. They are always set at 60 Hz. So, how is it that Apple is doing it when I have Apple LCD panels on a Mac? Hmmmm……..
    _______________________________
    Wayne Carey
    Schazam Productions
  • David
    January 12, 2006 at 10:50 pm
    How would this effect my setup when the Kona LH card’s default Kona output is the Mac desktop? My 3 monitor configuration has 2 mac LCD’s with n/a selected in screen rates, and my Sony monitor as 59.9hz with option only to change to 60hz. Even when FCP controls the card output, would the default settings create a playback problem… and dropped frames?
  • George Bellias
    January 13, 2006 at 4:32 am
    Is anyone experiencing this drop frame issue? I’m configuring a system now (Kona 3 & a Quad) and prefer the Dell 2405 over the Apple 23″ Cinema based on my research.
    George Bellias
    Jade Productions
  • Ron Thompson
    January 13, 2006 at 6:20 am
    Quite honestly, I think this is a non-issue. I run 2 Dell 2001 LCD monitors (which I LOVE because of their 4 switchable inputs) and I have never had any drop frame issues. You can’t change the rates in the System Preferences nor Dell monitor Image Settings. They all play nice together…and these seem to be the unchangable defaults. Maybe the DVI connection has something to do with it? I can access image controls when I switch to composite and Y/C inputs. I don’t have the VGA hooked up….maybe one day I’ll hook up the old G4 and test it out. Somehow I get the feeling the settings will open up then.
    Ron
