Activity › Forums › Adobe After Effects › from monitor to TV screen
  • from monitor to TV screen
    Posted by Eddy Rose on February 9, 2011 at 5:11 pm
    Okay,, this question is going to sound pretty retarded no matter how I phrase it so here goes:
    What is the typical procedure for hooking up a TV or some sort of TV calibrated monitor to my AE previewer?
    Scott Roberts replied 15 years, 7 months ago 3 Members · 2 Replies
  • Kevin Camp
    February 9, 2011 at 5:38 pm
    typically you’d have a video i/o card (like those from blackmagic, aja, matrox…), which would allow for ingesting and outputting video to and from a tape (or other baseband device). those cards also have monitoring ports, and that’s normally the port that you’d view on a broadcast monitor, though you could connect straight to the output.
    you can also use a firewire port to a camera that has a broadcast monitor connected.
    i may be wrong, but i think with later versions of ae, if you have a video card that has 2 dvi ports, and you have a dvi broadcast monitor, you can set the preview to use the second port to display the preview.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Scott Roberts
    February 12, 2011 at 4:26 am
    Canopus ADVC-300 (or another model) or a Firewire DV Camera…those are inexpensive solutions.
    https://www.graphicsdump.com
