Activity Forums Adobe After Effects From MacbookPro to Windows…
  • From MacbookPro to Windows…
    Posted by Benjamin Pastrana on March 8, 2011 at 4:35 am
    I have a Macbook Pro 2.53 Ghz Intel Core 2 Duo with 4GB RAM 1067 Mhz DDR3
    but is imposible to render with AECS5!
    I was Thinking on buying the new Macbook Pro or a Windows Laptop!
    I this configuration good to work with AE CS5?
    Asus – Laptop / Intel® Core™ i7 / monitor 17.3″ / memory 6GB /HD 640GB
    OR: MacBook pro Intel Core i7 with 8 gyg Ram?
    thank you in advance for your comments!
    Benjamin
    Walter Soyka replied 15 years, 6 months ago 5 Members · 4 Replies
  • Tudor “ted” jelescu
    March 8, 2011 at 2:57 pm
    I would go for the Mac, always, if I had my choice. That bing said, an Alienware MX17, i7, 8gb ram is not a bad choice either.
    And I would stay away from Acer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Brian Charles
    March 8, 2011 at 6:27 pm
    I have the same Macbook Pro you currently have but I have 8 GB or RAM in it. While it is slower than my Mac Pro desktop, it renders fine.
  • Erik Waluska
    March 8, 2011 at 6:56 pm
    Yeah, 4GB of RAM is your problem, not the laptop. My Mac Pro desktop at work is a few years old and only had 4GB of RAM when we first installed CS5 and it was horrible. Upgraded to 8GB and it works fine now.
  • Walter Soyka
    March 8, 2011 at 7:59 pm
    [Benjamin Pastrana] “I have a Macbook Pro 2.53 Ghz Intel Core 2 Duo with 4GB RAM 1067 Mhz DDR3 but is imposible to render with AECS5!”
    AE renders faster through multiprocessing, where it runs a couple instances of the renderer simultaneously. Each instance works on its own frame, on its own core (physical or virtual), and in its own space in RAM.
    If you have multiprocessing turned on with only 4GB of RAM, you should turn it off! When your system is that memory-constrained, multiprocessing will actually hurt your render performance.
    Does your new computer really have to be a laptop? You’d get way better performance for the same price on a desktop system with multiple cores and lots of RAM. You could always keep your current laptop for when you really require portability.
    Walter Soyka
