Activity Forums Avid Media Composer From FinalCut to Nitris DS (or MC at least)
  • From FinalCut to Nitris DS (or MC at least)
    Posted by Xavier Gruselle on September 13, 2009 at 9:12 am
    Hi everybody,
    I want to know if there is an export format in FinalCut that is easily importable in Avid (DS v8 + Qt 7.1 or MC 3.5) and lossless. I don’t want to buy plugins like AutomatickDuck :S
    I tried with uncompressed 10bits 422 BlackMagic but it doesn’t work on the Avid side (BlackMagic’s codecs are installed on the DS).
    Should I try with standard uncompressed 10bits 422 ? IMX ? Is it hopeless ?
    Thanks in advance for your help !
    Xavier Gruselle replied 17 years ago 4 Members · 5 Replies
  • Job Ter burg
    September 13, 2009 at 10:51 am
    Why not install the Avid codecs on the FCP side, then export as Avid Uncompressed or DNxHD?
  • Xavier Gruselle
    September 13, 2009 at 12:21 pm
    Thank you for your answer. In fact, the problem is that I can’t access the “FCP side” because it belongs to a customer.
    But I’m curious : If I use Avid codec (such as DNx), which wrapper should I use ? *.mov ?
    Thank you !
    (Any other suggestion -> do not hesitate 😉
  • Grinner Hester
    September 13, 2009 at 3:05 pm
    Yes, .mov. You’ll find the animation codec is generic and will work with anything. You won’t have fast import on the avid side unless using an Avid codec. I recomend the uncompressed meridien codec.
  • Ed Cilley
    September 16, 2009 at 3:33 am
    [Xavier Gruselle] “the problem is that I can’t access the “FCP side” because it belongs to a customer.”
    I don’t understand. If you can’t access the FCP side, then how are you accessing the clips? Anyway, like Grinner said, the Animation codec is the most compatible format. The files can get huge, but it works – and that’s what you are looking for. Animation codec works for SD and HD.
    Are you exporting a finished timeline or individual clips? Depending on what the original clips are, the Avid may be able to import without any conversion. If you are exporting a finished timeline and want it easily importable, then an Animation QT is your choice.
    Ed
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Xavier Gruselle
    September 16, 2009 at 10:55 am
    Hello,
    Thank you for your answer. In fact, the FCP side belongs to a customer so it’s difficult to ask him to install the Avid codecs :S
    I know the Animation codec is lossless but the problem is that it works in RGB mode and the native video is in YCrCb so I’m afraid changing the color format will damage the quality.
    I tried with uncompressed 10bits 422 standard (not BlackMagic), it worked with my FCP but not with the customer one.
    So, I don’t know… Maybe transcoding in “uncompressed standard” with third party softwares… Any other lossless solution ?
